Agree.@banger what speed are you expecting exactly from a single client in Load Balance mode?
You're getting higher than I would have expected.
It would be convenient if ASUS could add Quad9 DNS to this firmware.
If you mean on the WAN dropdown, more important would be to remove the Symantec DNS servers, as that service was discontinued two years ago, back in November 2018.
The dropdown list also needs to be retrieved over https instead of http. When accessing the web interface over https, Chrome (among others) will refuse to retrieve the Asus-hosted DNS server list over http, as mixed content is no longer allowed. That prevents the dropdown from appearing at all when accessing your router over https.
Yeah, I can never remember Quad9's IP when I have to enter it manually.![]()
and make the DNS dropdown list function over https.
What kind of ugliness? I have had a couple of disconnects in short succession but it is typically the time of the day when ISPs reboot edge routers.Grr im having some ugliness with my DSL and not sure if its the router or the connection which only coincidently started around the time of the last beta update...
And the modem isnt being helpful ..... partially because its in bridge mode...
-J
Cool! Does this need a DEDICATED wireless backhaul or will a wireless backhaul that clients can connect to also works?Mali,
Yes it works, I read you post, pulled out my Ethernet Cable RJ45 on one of my AiMesh Nodes
View attachment 26831View attachment 26832
You can read the FAQ pointed in the 1st Post. For me I leave connection priority as "Auto"Cool! Does this need a DEDICATED wireless backhaul or will a wireless backhaul that clients can connect to also works?
Is it still needed to move the routers close to each other to initialize an AiMesh node wireless, or can it be done on wired connection with the distance kept?
Vispen74,Is it still needed to move the routers close to each other to initialize an AiMesh node wireless, or can it be done on wired connection with the distance kept?
| Thread starter | Title | Forum | Replies | Date |
| D | How can I do this using AsusWRT? | ASUSWRT - Official | 38 | |
| D | ASUSWRT 4.0 - What did I get wrong (this time..) | ASUSWRT - Official | 1 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
