I have not enjoyed the same level of connection stability for my 2.4 mobile client while working around the property, now and before I switched to using Smart Connect. TuneIn regularly stops streaming with a connection error when normally it does not. If feels like RC2-6 has a connection management issue.
Here's an abbreviated snip from the General Log:
Oct 18 12:06:15 kernel: D8
4:3C:0A:7A:A4 not mesh client, can't update it's ip
Oct 18 12:06:15 kernel: pgd = ffffffc011703000
Oct 18 12:06:15 kernel: [f6953510] *pgd=0000000011758003, *pud=0000000011758003, *pmd=00000000153c1003, *pte=0000000000000000
Oct 18 12:06:15 kernel: CPU: 0 PID: 31262 Comm: amas_lib Tainted: P O 4.1.27 #2
Oct 18 12:06:15 kernel: Hardware name: Broadcom-v8A (DT)
Oct 18 12:06:15 kernel: task: ffffffc01e86a080 ti: ffffffc013ef0000 task.ti: ffffffc013ef0000
Oct 18 12:06:15 kernel: PC is at 0xf6998a58
Oct 18 12:06:15 kernel: LR is at 0xf6996728
Oct 18 12:06:15 kernel: pc : [<00000000f6998a58>] lr : [<00000000f6996728>] pstate: 600f0010
Oct 18 12:06:15 kernel: sp : 00000000f69534f8
Oct 18 12:06:15 kernel: x12: 0000000000000000
Oct 18 12:06:15 kernel: x11: 00000000f6955ad4 x10: 0000000000000002
Oct 18 12:06:15 kernel: x9 : 00000000f6d82c92 x8 : 00000000f6a91000
Oct 18 12:06:15 kernel: x7 : 00000000f6955b20 x6 : 00000000f6a91cc0
Oct 18 12:06:15 kernel: x5 : 00000000f6a91cc0 x4 : 00000000f69535c0
Oct 18 12:06:15 kernel: x3 : 00000000000f7db0 x2 : 00000000f6955ae8
Oct 18 12:06:15 kernel: x1 : 00000000f6d82c92 x0 : 00000000fbad8004
<snip>
Oct 18 12:07:08 rc_service: amas_lib 31300:notify_rc restart_firewall
Oct 18 12:58:03 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) Link DOWN.
Oct 18 12:58:06 kernel: eth4 (Ext switch port: 3) (Logical Port: 11) Link UP 1000 mbps full duplex
Oct 18 13:15:09 roamast: determine candidate node [D4:5D:64:7B:5F:61](rssi: -52dbm) for client [90:C7
8:90:85:59](rssi: -68dbm) to roam
Oct 18 13:15:09 roamast: Roam a client [90:C7
8:90:85:59], status [0]
Oct 18 13:15:10 wlceventd: wlceventd_proc_event(469): eth5: Deauth_ind 90:C7
8:90:85:59, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Oct 18 13:15:10 wlceventd: wlceventd_proc_event(486): eth5: Disassoc 90:C7
8:90:85:59, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Oct 18 13:23:31 wlceventd: wlceventd_proc_event(505): eth5: Auth 90:C7
8:90:85:59, status: Successful (0)
Oct 18 13:23:31 wlceventd: wlceventd_proc_event(534): eth5: Assoc 90:C7
Oct 18 13:26:48 wlceventd: wlceventd_proc_event(486): eth5: Disassoc 90:C7
Oct 18 13:26:48 wlceventd: wlceventd_proc_event(505): eth5: Auth 90:C7
Oct 18 13:26:48 wlceventd: wlceventd_proc_event(534): eth5: Assoc 90:C7
Oct 18 13:26:48 kernel: 90:C7
8:90:85:59 not mesh client, can't update it's ip
Oct 18 13:26:48 kernel: pgd = ffffffc0117a6000
Oct 18 13:26:48 kernel: [f77cf510] *pgd=0000000009e0d003, *pud=0000000009e0d003, *pmd=000000001163b003, *pte=0000000000000000
Oct 18 13:26:48 kernel: CPU: 0 PID: 18021 Comm: amas_lib Tainted: P O 4.1.27 #2
Oct 18 13:26:48 kernel: Hardware name: Broadcom-v8A (DT)
Oct 18 13:26:48 kernel: task: ffffffc017671480 ti: ffffffc010d4c000 task.ti: ffffffc010d4c000
Oct 18 13:26:48 kernel: PC is at 0xf6f2ca58
Oct 18 13:26:48 kernel: LR is at 0xf6f2a728
Oct 18 13:26:48 kernel: pc : [<00000000f6f2ca58>] lr : [<00000000f6f2a728>] pstate: 600f0010
Oct 18 13:26:48 kernel: sp : 00000000f77cf4f8
Oct 18 13:26:48 kernel: x12: 0000000000000000
Oct 18 13:26:48 kernel: x11: 00000000f77d1ad4 x10: 0000000000000002
Oct 18 13:26:48 kernel: x9 : 00000000f7316c92 x8 : 00000000f7025000
Oct 18 13:26:48 kernel: x7 : 00000000f77d1b20 x6 : 00000000f7025cc0
Oct 18 13:26:48 kernel: x5 : 00000000f7025cc0 x4 : 00000000f77cf5c0
Oct 18 13:26:48 kernel: x3 : 00000000000f7db0 x2 : 00000000f77d1ae8
Oct 18 13:26:48 kernel: x1 : 00000000f7316c92 x0 : 00000000fbad8004
<snip>
Oct 18 13:54:01 rc_service: amas_lib 18035:notify_rc restart_firewall
I've made bold some suspicious entries... the first
D8
4:3C:0A:7A:A4 is a SONY AVR wired to the root node... the second
90:C7
8:90:85:59 is my 2.4 mobile client. There is only one weak 2.4 ch9 20MHz WiFi signal overlapping my ch11 signals.
OE
