RT-AC68U firmware was released already
Update 2020/11/12 (9.0.0.4.386.40947)
https://drive.google.com/drive/folders/1UHZwR1buG-nei8fne9d9OktOS2gZy6Hs?usp=sharing
This version includes 19 models:
ZenWiFi: XT8(RT-AX95Q), XD4(RT-AX56U_XD4), CD6(RT-AC59_CD6)
GT series: GT-AX11000,GT-AC5300, GT-AC2900
RT series: RT-AX88U, RT-AX92U, RT-AX86U, RT-AX82U, RT-AX58U, TUF-AX3000, RT-AX56U, RT-AX55
RT series: RT-AC5300, RT-AC88U, RT-AC3100, RT-AC86U, RT-AC68U
Change log
- Fixed Ethernet backhaul through switch issue
- RT-AX86 and GT-AX11000 support 2.5G port as ethernet backhaul
- Fixed RT-AX55 firmware update issue.
- Fixed speedtest issue for android app.
- Fixed mesh node guest network internet connection issue.
- Fixed ap mode guest network issue.
- Added security patch
- Fixed repeater mode UI bug.
So ASUS R&D referred me to this thread because of my upload speed issues (getting 50% of my broadband).
Sadly, latest BETA Build do not solve my issues.
Darn... ASUS, when do we solve that ?!
I can confirm that AP mode guest can be connected to now, however there is no network isolation so it's not really a usable guest network.
Solve what... can you provide some context?
OE
Got 1G plan over Fiber.
Bought 2 units AX88U in August- and simplest thing like getting my 100% upload speed- not happening.
Im getting 50% of my upload speed- 50-60Mbps, usually towards 50Mbps.
Have you speed tested with a PC wired directly to your fiber box?
OE
Yup, speeds are fine directly to the modem - Dlink media converter- 950/110Mbps.
Change log
On RC2-8, after factory resetting the RT-AX58U node(core is a RT-AX58U also), it did not want to join AiMesh without using the cable. Must of tried around 10 times but only succeeded once I connected the cable. Also I'm noticing that clients are not switching to the node like it did on 384, after 1 hr, I only have 1 client on it when I usually have 5. If I downgrade to the node to 384 and rejoin it to AiMesh, all 5 of my clients join the node quick, literally seconds after the node boots and connects.
How are speeds wired to a reset router, minimally configured... no QoS or traffic management features?
OE
That's the thing - In wired speed test- everything is good.
In wired file upload though- which is where you use the upload- 50Mbps (like on the wireless speedtest).
@karma
Well I guess it’s still a little “better than nothing” in that you can at least have separate Guest SSID’s which you can turn on/off, change passwords on etc without mucking about with your “main” SSID name/password, but yes isolation would be very desirable.
Funnily enough from the very early days of AIMesh 1.0 betas I’d always assumed that achieving Guest Isolation across the AIMesh would be an unsolvable limitation/side-effect WHEN the “Parent” is in AP Mode (and thus not Routing) - am I incorrect in my assumptions?
Perhaps @ASUSWRT_2020 can respond and clarify as to whether this is ever going to be achievable/fixable in the current development cycle?
to be honest it's not really better than nothing because it's dangerously misleading to call it a 'guest' network without isolation. if guest network isolation is not possible in AP mode it should be made very clear in the UI or the feature should be disabled.
| Thread starter | Title | Forum | Replies | Date |
| D | ASUSWRT 4.0 - What did I get wrong (this time..) | ASUSWRT - Official | 1 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
