I have an RT-AC1750 B1 currently running Merlin firmware 386.1_2. It is serving as the router and the only access point in my home network. I also have a pi-hole for DNS ad-blocking. My ISP provides an ipv6 connection, but I currently have it disabled in the router web interface because enabling it breaks the pi-hole ad-blocking. I think the issue stems from the fact that the router always advertises its own ipv6 address as DNS server, even though I put the pi-hole ipv6 address in to the router's ipv6 DNS server settings. Devices are using the router as ipv6 name server and using an upstream DNS provider (my ISP's ?) rather than the pi-hole.
I have seen several posts about modifying dnsmasq.postconf to change the router's behavior in this regard, but I wanted to look at other simpler options since I'm a novice at all this.
I saw on another thread that john's 374 LTS fork has an option in the web interface to stop the router from advertising its own ipv6 address, so I thought maybe I would give that a try. Basically just like the option that is available at (LAN>DHCP>Advertise router's IP in addition to user-specified DNS) but for ipv6.
So I have a few questions:
1) Is the RT-AC1750 B1 supported by john's fork, and if so, which hardware version should I install? With regular Merlin, my understanding is that the RT-AC1750 B1 uses the same firmware as the RT-AC68U.
2) Are there any downsides I should be aware of with using john's fork? Security patches just as good and up to date? I don't use any of the advanced features of the router's firmware, just the most basic routing and wireless access point features.
3) Am I making too big a deal about ipv6 in your opinion? Should I just leave it disabled and move on with the regular Merlin firmware, enjoying my ad-free but ipv4-only network?
Thanks in advance!
Thanks in advance!
