Greetings!
I recently migrated my main router (RT-AX88U) to Asuswrt-Merlin. It worked like a charm. However, when I try to do the same with my AiMesh node (RT-AX56U) I receive the message "Unable to connect to the Parent AP."
My main router is in Wireless router mode / AiMesh Router mode (Default) and it's now running Asuswrt-Merlin Firmware Version 386.8 (latest). The AiMesh Node is running Asus default firmware Version 3.0.0.4.386_49380-gb9aceaf (also latest for this model). Everything seems to work as it should be in AiMesh mode between the router/node as far as I know (topology shows both itens, I can use the node with no issues, etc.).
However, one thing does not work: I can't connect to the AiMesh node's webgui interface at all anymore.
When I point the browser to the hostname/ip of the aimesh node, it says "Detecting AiMesh router...", then says "Unable to connect to the Parent AP.", and suggests me to "Ensure that your AiMesh router has been powered on." & "Reboot your AiMesh router and try again."
Also, if I try to upgrade my standard Asus firmware to Asuswrt-Merlin it pops up the same window and I got the same error (see below).
I tried rebooting. But obviously that doesn't work.
Anyone has any clues why I can't get to the node's webgui at all? How can I upgrade it's firmware now? Or is it not supposed to work anymore?
Thanks.
Thanks.
