Asuswrt-Merlin Openvpn in combination with Raspberry Pi
JanWillem
Hello,
I started today with setting up and Openvpn connection to a raspberry Pi.
The raspberry pi is configured with the procedure as described on this link.
http://readwrite.com/2014/04/10/raspberry-pi-vpn-tutorial-server-secure-web-browsing
On my ipad and computer works the vpn connection without any problems.
But with the router RT-AC56U with asuswrt-merlin I dont get a connection.
the log files on the Raspberry pi
Tue Aug 19 21:16:46 2014 192.168.24.1:34837 Re-using SSL/TLS context
Tue Aug 19 21:16:46 2014 192.168.24.1:34837 LZO compression initialized
Tue Aug 19 21:16:46 2014 192.168.24.1:34837 TLS_ERROR: BIO read tls_read_plaintext error: error:140890C7:SSL routines:SSL3_GET_CLIENT_CERTIFICATE:peer did not return a certificate
Tue Aug 19 21:16:46 2014 192.168.24.1:34837 TLS Error: TLS object -> incoming plaintext read error
Tue Aug 19 21:16:46 2014 192.168.24.1:34837 TLS Error: TLS handshake failed
I also made a list of the .ovpn file
client
dev tun
proto udp
remote myip 1194
resolv-retry infinite
nobind
persist-key
persist-tun
mute-replay-warnings
key-direction 1
cipher AES-128-CBC
comp-lzo
verb 1
mute 20
<ca>
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
</ca>
<cert>
</cert>
<key>
-----BEGIN RSA PRIVATE KEY-----
Proc-Type: 4,ENCRYPTED
DEK
-Info: DES-EDE3-CBC,2xxxxxxxxxxxxxF
-----END RSA PRIVATE KEY-----
</key>
<tls-auth>
# 2048 bit OpenVPN static key
-----BEGIN OpenVPN Static key V1-----
-----END OpenVPN Static key V1-----
</tls-auth>
Is it possible that the client key is a problem, because it is encypted with DES3 ?
This .ovpn file is working on my Ipad and computer.
I use firmware version 3.0.0.4.376.45_0
Hope anybody could help me
problem solved
encrypted client key is not working
when I dont use a encrypted key everything is working.
