asuswrt-merlin rebooted itself
Chrysalis
no error in log other than seeing the boot process and low uptime.
any idea what might be the reason? router was pretty much idle, no torrents etc.
also so I dont make another new thread.
I have a script that is supposed to mount my cifs.
admin@RT-N16:/jffs/scripts# ls -l
-rwxr-xr-x 1 admin root 108 Jan 1 2011 init-start
admin@RT-N16:/jffs/scripts# pwd
/jffs/scripts
then if I run the script manually it works.
admin@RT-N16:/jffs/scripts# ./init-start
admin@RT-N16:/jffs/scripts# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
proc on /proc type proc (rw)
tmpfs on /tmp type tmpfs (rw)
devfs on /dev type tmpfs (rw,noatime)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
/dev/mtdblock4 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw)
\134\134192.168.1.124\134asusmerlin on /cifs1 type cifs (rw,mand,unc=\\192.168.1.124\asusmerlin,username=Chris,uid=0,gid=0,rsize=16384,wsize=57344)
on boot it does nothing.
any ideas on this also?
thanks
We have to guess what firmware version you are running?
Impossible to tell. The router will reboot itself whenever the kernel or a driver crashes, for instance. Could also be a power fluctuation.
/jffs/scripts
init-start is way too early in the boot process, the network isn't configured at that point. Move your command into services-start rather, the LAN should be up and running at that stage.
