ColinTaylor
Part of the Furniture
How far away from the router is the air conditioner?
Do you have a link to the user manuals? What is the model number?
I've run out of ideas. Have you asked the manufacturer about the WiFi requirements (e.g. bands, channels, etc.)?
a device that only supports short preamble will not see the SSID for a device that is configured in Long preamble type. the device would have to be switched to long + short or to Long only ---- or the router has to be switch to support short and not long. it would be nice if your router could run with both short +long.I will try both suggestions in evening and update you guys. Thankx
He's already stated that he's done that in post #7.Don't test with Control Channel on 'Auto'. Test instead with additional channels 6 and 11 too.
Again, he's done that already, post #3.As I have previously suggested and Grisu also mentions, test using the Guest Network with a different SSID and password. 8 characters, no spaces, no special characters, no punctuation, and no smiley faces either.
Password is irrelevant at this point as he cannot see to SSID to connect to it.For the password, use at least 16 characters with the same restrictions.
Not really. Apart from post #31 all of the previous tests were him doing exactly what we asked him to do. Post #31 was just a test of the preamble length, everything else had already been tested. If there's a problem with the testing methodology it's our fault not his.He keeps going back and forth on what he's testing (post 31). He needs to be more consistent and testing in a reproducible way.![]()
If this works and you feel the need that you need to adjust another setting- you can always adjust it. note - do a reboot in between each additional adjustment onward- wait for things to stabilize.View attachment 17415
this is what i would try on wireless page. - (you can test the preamble between long or short)
these are what i would put inside the wireless screen
note (do reboots in between any other changes you make)
Welcome To SNBForums
