Asuswrt-Merlin RT-AC87R
Jonathanrc73
I noticed that when configuring the 5 Ghz guest wifi the users are able to scan the internal network and can ping internal nodes.
Used IP Network Scanner (Lite) on IPAD Pro to test.
I validated that on the Guest Network configuration, Access Intranet is set to OFF on the 5 Ghz. network.
Is there a configuration piece I am missing here?
Thank you kindly,
Jonathan
The RT-AC87U's 5 GHz Guest is broken. Asus are aware of it.
