Asuswrt WebUI CPU Graph include AiMesh Nodes?
garycnew
All:
Does the Asuswrt WebUI CPU Graph include AiMesh Nodes? I've notice that when I execute a high cpu and zero bandwidth command on an AiMesh Node that it seems to be reflected within the Asuswrt WebUI CPU Graph.
Thanks.
Gary
No, CPU monitoring is local.
However keep in mind that if you generate a lot of traffic on a node, that traffic will eventually reach your primary router to get routed to the Internet, which will increase that main router's CPU load.
@RMerlin
My initial observation must have been a coincidence. Further high cpu and zero bandwidth load testing on various AiMesh Nodes supports your conclusion.
Appreciate your response.
Thank you for your great work.
With Great Respect,
Gary
@RMerlin
It turned out to be NFS traffic generated from the AiMesh Node.
Thanks, again, for all that you do.
Much Respect,
Gary
