ASWART AC68u - 2 routers LAN to WAN AP
Excellent work thanks to you ALL.
2nd) event my ISP,,,,IS,,,hacking & reconfiguring my router,,,how can I stop this....? ASUS route——>>Firewall device,,,Merlin command,,,or SonicWall....?
Can you rearrange these words into a coherent sentence please? ;)
...my ISP is hacking & reconfiguring my router...
:confused: Why do you think this? What firmware version are you running on your router?
Router login password changed,,,, all devices router Wi-Fi password access only via Mac filter. ( router setup off line —> NO WAN ,,,,, connect VIA LAN only for setup\access,,,then Locked out of router ONLY after connection to modem after 5-10min,,,,more than once.
Attempt to access router dash usual way 196.168.1.1,,, given ASUS iAcloud login,,,,dash,,,,any idea
Did you enable AiCloud on the router (Cloud Disk, Smart Access or Smart Sync)?
EDIT: Are you accessing your router with http://192.168.1.1 or did you disable HTTP access to the router?
https://www.snbforums.com/threads/can-only-get-to-aicloud-home-page.8232/
I suggest that you factory reset the router by pressing the reset button. Then do the minimum amount of configuration to get it online and then update the firmware to the latest version. Follow that with another factory reset before setting up your router properly.
Router login password changed,,,, all devices router Wi-Fi password access only via Mac filter. ( router setup off line —> NO WAN ,,,,, connect VIA LAN only for setup\access,,,then Locked out of router ONLY after connection to modem after 5-10min,,,,more than once.Attempt to access router dash usual way 196.168.1.1,,, given ASUS iAcloud login,,,,dash,,,,any idea
I have an idea! You need to change your keyboard first. Any recent water damage around "," and "." keys?
Listen, people are trying to help you here. Writing in gibberish is a demonstration of total lack of respect to everyone's time. I had to read your posts three times slowly in order to understand what you are trying to say. Seriously?
You don't need Asuswrt-Merlin firmware.
Revert to stock ASUS firmware, reset both routers, follow ASUS setup guides on the previous page. Simple.
