Entware atmt freeze on entware installation
Olndo Pindaro
RT-AX86S - Merlin 388.2.2
try to install with AMTM entaware terminal freeze here. I can do? (for installing i used the diversiti site option)
Olind0
  • syslog.txt
That‘s because you have Download Master installed. I should have included that check that Diversion does into the amtm code. Entware and Download master CANNOT coexist on the router because they both use the /tmp/opt link.
thanks I realized. now i tried to install rtorrent... failed, deluge... failed and now i have the usb full of conflitting rubish. Reformat pen and try again ?
But i kindly ask you tu suggest a tutorial for installing a download manager that works.
Thnaks you your kindness
Olindo
Olindo
Reformat is a good option. I cannot give advice on a working download manager for a router as mine is installed on a separate Linux box. The router is not an ideal file handler for such large files.
Search the forum for posts, there are several.
@Olndo Pindaro, go easy on this router because it has very little RAM available after boot. You perhaps noticed already. It's a good router for whatever is available in Asuswrt, but may struggle with add-ons in Asuswrt-Merlin. External HDD attached to it - not recommended. Swap file won't help.
  1. formated usb-clean
  2. clean up jffs
  3. amtm entware install
  4. opkg install rtorrent-easy-install
  5. Starting lighttpd... already running.
    Starting rtorrent... failed.
    Collected errors:
    * pkg_run_script: package "rtorrent-easy-install" postinst script returned status 255.
    * opkg_configure: rtorrent-easy-install.postinst returned 255.
    olindo@RT-AX86S-01C8:/tmp/home/root#
    where i can investigate?
