Authentication in an Wired Network
gragnous
Can you point me in the right direction to learn about how to authenticate clients in a wired network, similar to a key in a WiFi network?
I'm hoping there is a simple way to keep an unapproved device from being plugged into and gaining access to the data on a wired network. We're currently using a off the shelf router flashed with DD-WRT, but I've been experimenting with and will likely switch to PFsense.
There are a few ways to do this based on what your needs really are;
If you are just looking to block access to the internet . . . a captive portal authenticating to either a simple passcode or database will work.
If you are looking to completely block access to the LAN . . . 802.1x authenticated off of a RADIUS server is considered industry standard.
He's proposing the wire, so RADIUS is the answer with a managed switch perhaps..
