AutoBW: Automatically set QoS bandwidth using spdMerlin
The up/down rates need to be rounded from decimal to integer before using in the if statements. It’s an AutoBW change needed.
Does AutoBW work with cake or is on strictly for FreshJr or FlexQoS?
I know it will work with any usage of Adaptive QoS. Can't speak to cake, but I think the output of the AutoBW tests are relevant if performed without QoS shaping the test traffic.
is this the latest/recommended version?
thanks
anyone running this on a schedule in non-test mode, with FlexQoS? how's your experience?
This worked for me (08.07.2020):
*Please pre-install spdmerlin via amtm and let it run for 1 Time before following the installation of AutoBW
Install Script with this command ->
curl "https://raw.githubusercontent.com/jackyaz/AutoBW/master/AutoBW" -o /jffs/scripts/AutoBW && chmod 755 /jffs/scripts/AutoBW
Install "bc" via Entware ->
opkg install bc
Install "nano" via Entware ->
opkg install nano
Start Script one time with
Edit AutoBW for your needs and remove Test Mode
nano /jffs/scripts/AutoBW
Nano into services-start and add a Cron to let AutoBW adjust QOS speed for example every 10 Hours.
nano /jffs/scripts/services-start
and add this ->
cru a AutoBW "0 */10 * * * /jffs/scripts/AutoBW"
Enjoy.
--------EDIT-------
Still getting some Syntax errors with latest stable Merlin release 384.18 and spdmerlin 3.6.1
@Jack Yaz
TEST MODE: No changes will be made.
              ---------------- SPDMERLIN -------------
                Download (Kbps)       Upload (Kbps)
Test  1 of  2       75786.2              35502.1
Test  2 of  2       78551.0              35502.1
Average             77168.6              35502.1
Scale Factors          0.85                 0.85
Scaled Speeds       65593.3              30176.8
              ----------------- QOS ----------------
Previous              63962.0             25867.0
New (from above)      65593.3             30176.8
[: 25866.9999104: bad number
[: 63961.9999744: bad number
Scaling by              1.026               1.167
              ====================================== DOWNLOAD ======================================
              ----------------- RATE -----------------    ----------------- CEIL -----------------
Class            Previous (Kbps)        New (Kbps)           Previous (Kbps)         New (Kbps)
11                     9594.0             9838.7                   63962.0            65593.3
10                     3198.0             3279.6                   63962.0            65593.3
13                    12792.0            13118.3                   63962.0            65593.3
12                    19188.0            19677.4                   63962.0            65593.3
15                     3198.0             3279.6                   63962.0            65593.3
14                     6396.0             6559.1                   63962.0            65593.3
17                     3198.0             3279.6                   63962.0            65593.3
16                     6396.0             6559.1                   63962.0            65593.3
              ======================================= UPLOAD =======================================
(standard_in) 1: syntax error
 0                        0.0                0.0                       0.0                0.0
also getting this error without Testmode
Test  1 of  4       77312.0              35522.6
Test  2 of  4       78663.7              35512.3
Test  3 of  4       78725.1              35409.9
Test  4 of  4       78776.3              35502.1
Average             78369.3              35486.7
Scaled Speeds       66613.9              30163.7
New (from above)      66613.9             30163.7
Scaling by              1.041               1.166
11                     9594.0             9991.8                   63962.0            66613.9
10                     3198.0             3330.6                   63962.0            66613.9
13                    12792.0            13322.4                   63962.0            66613.9
12                    19188.0            19983.5                   63962.0            66613.9
15                     3198.0             3330.6                   63962.0            66613.9
14                     6396.0             6661.2                   63962.0            66613.9
17                     3198.0             3330.6                   63962.0            66613.9
16                     6396.0             6661.2                   63962.0            66613.9
 0                        0.0                0.0                       0.0                0.0
Illegal "prio"
Usage: ... qdisc add ... htb [default N] [r2q N]
                      [direct_qlen P]
 default  minor id of class to which unclassified packets are sent {0}
 r2q      DRR quantums are computed as rate in Bps/r2q {10}
 debug    string of 16 numbers each 0-3 {0}
 direct_qlen  Limit of the direct queue {in packets}
... class add ... htb rate R1 [burst B1] [mpu B] [overhead O]
                      [prio P] [slot S] [pslot PS]
                      [ceil R2] [cburst B2] [mtu MTU] [quantum Q]
 rate     rate allocated to this class (class can still borrow)
 burst    max bytes burst which can be accumulated during idle period {computed}
 mpu      minimum packet size used in rate computations
 overhead per-packet size overhead used in rate computations
 linklay  adapting to a linklayer e.g. atm
 ceil     definite upper class rate (no borrows) {rate}
 cburst   burst but for ceil {computed}
 mtu      max packet size we create rate map for {1600}
 prio     priority of leaf; lower are served first {0}
 quantum  how much bytes to serve from leaf at once {use r2q}
TC HTB version 3.3
thanks for this info. i've disabled spdmerlin scheduled runs, and instead have AutoBW running every 30min (my speeds fluctuate a lot). and i still get spdmerlin webgui results. really nice.
the only thing missing from this script is the option to manually set speed values: "/jffs/scripts/AutoBW 300 10", and the option to add the crontab entry. or maybe just merge AutoBW functionality into spdmerlin
I'm contemplating absorbing AutoBW's features into spdMerlin. How are people currently using it? Would users want to specify X runs every 30/60minutes, and use the average for the result? Or 1 run per 30/60 as spdmerlin does now, and average the last X runs?
maybe config allows to:
- specify frequency to run spdMerlin: every 30, 60, 120, etc minutes
- specify if and how many recent results to average when checking for qos speeds
- specify how large of change needed (%), to trigger a qos speed correction (to avoid constant changes with minor differences)
- specify if each spd run should be single or double.
- qos corrections would use wan results only(?)
I have it running as a cron job through the middle of night, found out pretty fast if i let it run during heavy usage times it skewed results pretty bad. For some reason when I set it to run at boot up it sets my manual bandwith back to automatic half the time(probably 0 and 0?) Averaging results over the last X number of runs would be great.
Started absorbing this into spdMerlin - I think rather than meddle with tc manually as the script does now, is simply update the bandwidth values and issue a qos restart. asus fw and flexqos (if installed) can handle the tc calculations from there.
FYI, FlexQoS won’t do anything on just a restart_qos. It takes a restart_firewall to get off its a$$.
Also, do you think bc is really needed still?
noted re. firewall restart, perhaps best to issue both?
probably not, since all that's needed with my proposed approach is to multiply Mbps to Kbps!
edit: tell a lie, multiplying by decimals might need bc unless I use my awk method from other scripts
It would be ungentlemanly to restart the firewall only for FlexQoS when a QoS restart would be enough for non-Flex users. After a QoS restart, if /jffs/addon/flexqos/flexqos.sh is present, you can fork a /jffs/addon/flexqos/flexqos.sh -check & and it will cleanup the needed rules. At least until I can think of a better way to handle these restarts. I think FreshJR used firewall-restart to ensure we receive the correct wan ifname for iptables, but I’ve always seen the mangle table flushed on a restart_qos so I should handle both events in the future.
Another kludge is to set the bandwidth and restart QoS around 03:25 AM just before the nightly FlexQoS persistence check. Assuming it becomes an automated process...
