tastle
So this is the first time I've ever encountered this. I just updated my router and then I noticed that my Nord VPN was failing to connect with an OpenSSL error.
May 5 09:32:27 vpnclient5[10809]: VERIFY ERROR: depth=1, error=certificate is not yet valid: C=PA, O=NordVPN, CN=NordVPN CA6, serial=4764208788777194848
May 5 09:32:27 vpnclient5[10809]: OpenSSL: error:1416F086:lib(20):func(367):reason(134)
I noticed that the system date was wrong. I tried:
* Changing TZs
* Toying with the DST values
* Soft reboot
* Hard reboot
Nothing worked. I finally just sshed into the router and set the date myself (not ideal... it should be syncing to pool.ntp.org).
After I set the date, the message that I was seeing under the NTP Server field ("Reminder: The system time has not yet been synchronized with an NTP Server. FAQ") finally went away, and my VPN is now working.
Has anyone ever seen this before?
* Changing TZs
* Soft reboot
* Hard reboot
