astephon88
I am currently using custom DDNS to update cloudflare DNS with the following ddns-start script:
and inadyn.conf:
After updating to 388.6, inadyn is failing to verify the server certs for cloudflare and the services it uses for checkip. I'm seeing the following errors in the system logs:
Bash:
#!/bin/sh
inadyn --once -f "/jffs/inadyn.conf" -e "/sbin/ddns_custom_updated 1" --continue-on-error "/sbin/ddns_custom_updated 0"
and inadyn.conf:
JSON:
provider cloudflare.com {
username = <redacted>
password = <redacted>
hostname = <redacted>
ttl = 60
proxied = false
If I revert back to 388.5, everything works as expected again. Any ideas on how to get this fixed?Feb 23 20:40:23 watchdog: start ddns.
Feb 23 20:40:23 ddns: update CUSTOM , wan_unit 0
Feb 23 20:40:23 ddns: Clear ddns cache.
Feb 23 20:40:23 custom_script: Running /jffs/scripts/ddns-start (args: x.x.x.x)
Feb 23 20:40:23 inadyn[3976]: In-a-dyn version 2.10.0 -- Dynamic DNS update client.
Feb 23 20:40:23 inadyn[3976]: Guessing DDNS plugin 'default@cloudflare.com' from 'cloudflare.com'
Feb 23 20:40:23 inadyn[3976]: Certificate verification error:num=20:unable to get local issuer certificate:depth=1:/C=US/O=DigiCert Inc/CN=DigiCert Global G2 TLS RSA SHA256 2020 CA1
Feb 23 20:40:23 inadyn[3976]: OpenSSL error: 4144561792:error:1416F086:lib(20):func(367):reason(134):NA:0:
Feb 23 20:40:23 inadyn[3976]: Communication with checkip server 1.1.1.1 failed, run again with 'inadyn -l debug' if problem persists
Feb 23 20:40:23 inadyn[3976]: Retrying with built-in 'default', api.ipify.org ...
Feb 23 20:40:23 inadyn[3976]: Certificate verification error:num=20:unable to get local issuer certificate:depth=2:/C=US/O=Google Trust Services LLC/CN=GTS Root R1
Feb 23 20:40:23 inadyn[3976]: Failed to get IP address for default@cloudflare.com, giving up!
Feb 23 20:40:23 inadyn[3976]: Update forced for alias home.stephon.dev, new IP# 71.166.45.148
Feb 23 20:40:23 inadyn[3976]: Certificate verification error:num=20:unable to get local issuer certificate:depth=1:/C=US/O=Cloudflare, Inc./CN=Cloudflare Inc ECC CA-3
