AX 86u getting weird errors in logs
tilliks
Hello,
I have an ax86u with the current merlin firmware. My internet has been weird, and I wonder if this error log is the issue. discord keeps disconnecting and reconnecting, battle.net client keeps disconnecting, resulting in me unable to play games on it. If i am playing an FPS, while using discord to communicate with friends, the game itself is running smooth, but my discord just keeps disconnecting and reconnecting right away.
Apr 12 15:17:21 acsd: acs_candidate_score_intf(1133): eth7: intf check failed for chanspec: 0xe832 (36/160)
Apr 12 15:17:21 acsd: acs_candidate_score_bgnoise(1602): eth7: bgnoise check failed for chanspec: 0xe832 (36/160)
Apr 12 15:17:21 acsd: acs_candidate_score_txop(1860): eth7: txop check failed for chanspec: 0xe832 (36/160)
Apr 12 15:17:21 acsd: acs_candidate_score_intf(1133): eth7: intf check failed for chanspec: 0xe932 (40/160)
Apr 12 15:17:21 acsd: acs_candidate_score_bgnoise(1602): eth7: bgnoise check failed for chanspec: 0xe932 (40/160)
Apr 12 15:17:21 acsd: acs_candidate_score_txop(1860): eth7: txop check failed for chanspec: 0xe932 (40/160)
Apr 12 15:17:21 acsd: acs_candidate_score_intf(1133): eth7: intf check failed for chanspec: 0xea32 (44/160)
Apr 12 15:17:21 acsd: acs_candidate_score_bgnoise(1602): eth7: bgnoise check failed for chanspec: 0xea32 (44/160)
Apr 12 15:17:21 acsd: acs_candidate_score_txop(1860): eth7: txop check failed for chanspec: 0xea32 (44/160)
Apr 12 15:17:21 acsd: acs_candidate_score_intf(1133): eth7: intf check failed for chanspec: 0xeb32 (48/160)
Apr 12 15:17:21 acsd: acs_candidate_score_bgnoise(1602): eth7: bgnoise check failed for chanspec: 0xeb32 (48/160)
Apr 12 15:17:21 acsd: acs_candidate_score_txop(1860): eth7: txop check failed for chanspec: 0xeb32 (48/160)
I am not well versed in these type of things. Can someone help me what this means?
Hello,
@tilliks
I also have an RT AX86U router with recently loaded Merlin firmware. I am getting these same errors in my system log and erratic connection issues, similar to those you describe. I don't game, but my VoIP connection and streaming TV connections are dropping and buffering in similar time periods as the errors.
Did you ever receive any input or determine the root cause?
I too used to get these errors until i learnt what it is.
What I did was to get an app (WiFi Analyzer on Windows) and see which channel is best for each bands. If you have 2.4Ghz set at 20/40MHz, you will get these chanspec logs. Set 2.4Ghz either to 20MHz only or 40MHz only depending on your clients connecting to this WiFi, and find set a channel according to the app if you have it, or by setting it to none overlapping channels (1,6,11). Same with 5Ghz WiFi but I have it set at 20/40/80/160Mhz with control channel 52. And I don’t have these logs anymore.
For me it was trial and error to find what’s the best channel in my area with lots of flats/buildings around. Can’t even get 5G signal on my phone.
Was quite fun reading about WiFi frequencies. But best to set control channel rather than auto. Thread '[GUIDE] Troubleshooting wifi issues'
Most WiFi Analyzer apps don't show you available bandwidth. Not good for best channel selection. They only show how many APs around are tuned to specific channels. A channel with one only AP may be the worst one. The app also shows what on-device Wi-Fi controller sees around, not the router.
Too bad WinFI is already dead...
Nice to know, considering the author didn't even reply when I tried to reach out to him a few months ago asking if the project was dead or not.
Hopefully this new build no longer has a timebomb. I was using a batch file to work around the timebomb.
WinFI 1.0.22.12 expired again on 1st April 2023. No updated version available for download yet.
Guess I better keep my launch batchfile around...
