Tech9
Part of the Furniture
I'll show you a screenshot of what I got/get
Is this device connected to the router's main Wi-Fi network?
yesIs this device connected to the router's main Wi-Fi network?
I don't know what your issue is. Accessing the WebUI is the simplest first step. It even pops up automatically in form of Quick Internet Setup right after reset on first connect to the default open Wi-Fi network. You need to read the User Guide and go from there. It's a home device for non-tech people.
Offizieller Support | ASUS Deutschland
Das ASUS Support Center hilft Ihnen Treiber, Handbücher und Firmware-Versionen herunter zu laden. Hier finden Sie auch FAQs und Troubleshooting Hilfenwww.asus.com
Note that it is generally strongly recommended by most here to disable (set to No) the Enable Web Access from WAN option in the router GUI > Administration > Remote Access Config section.
In a similar situation to mine, when flashing Merlin firmware, you should be able to see a message about CFE crash in the system log.
Attempt to find the router's IP address using Asus's 'Discovery' tool. If that still doesn't work, try using Asus's rescue mode to flash the latest official firmware, and then flash Merlin 387. This should allow you to see the detailed error messages in the system log. If you cannot even enter rescue mode, then it is likely that the router's 'CFE' is damaged.I can't log into the router ip address.
I just stumbled into the possibility about DOUBLE NAT.
Could that be an issue?
Also, still catching up on Ozark's thing about cable connection. Trying to wrap my head around that one.
is only through the phone app
Just called ASUS Tech Support
Thanks. But everything I can do, is only through the phone app. Without it, it's just a solid red on the Internet LED, which means the router doesn't recognize any Internet connection from the modem. ... While ISP and I can confirm that the modem works.
For some reason, I can only set up my regular ax86u through my phone app, and I cannot access my router through IP address (although I do know the IP address, which is the default manufacturer's).
I just ran a traceroute on terminal app:
How to identify and resolve double-NAT problems
We’ll show you how to eliminate this conflict between your router and your broadband gateway.www.pcworld.com
Well, I guess it doesn't seem to be Double NAT.
Forget about the App for a moment, open your browser on the phone, come to this thread on SNB Forums and click here:
I don't think Asus Tech Support can help you. It's not your router the problem, but the device you are trying to access the WebGUI with.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
