AX411 - $18.75
Found a quirk in :Linux upon doing a reboot for a kernel upgrade. Not sure what I was playing with before that caused it but, I might have been cleaning out some old firmware sitting in /lib/firmware or some other update. Anyway... the AX411 uses slightly different modules than the AX21x versions. They use the GF4 option instead of the TY that the others do. Thinking they were the same I looked up and down for the earliest AX210 package with the -39.ucode being the first I had recalled seeing in the firmware directory, I couldn't find it anywhere and then started playing with different kernel versions thinking it might be embedded in one of them. I stripped out the ucode files from the directory and imported only the GF4 modules
Maybe it was deleting the pnvm file during some tinkering and then the reboot was just coincidental w/o having put the file back. There seems to be something embedded in both versions of the card though making them look for version 72 of the firmware but, that doesn't exist anywhere but, 73 does but, they won't use it and fallback to 71. SMH @ Intel on this one. Since it's not a well documented card still at this point HTH someone searching google or the forum in getting it working on their system.
 sudo dmesg | grep iwlwifi
[    4.550491] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    4.556781] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-gf4-a0-72.ucode failed with error -2
[    4.558051] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[    4.558063] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[    4.558411] iwlwifi 0000:00:14.3: loaded firmware version 71.058653f6.0 so-a0-gf4-a0-71.ucode op_mode iwlmvm
[    4.847099] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6E AX411 160MHz, REV=0x430
[    5.024509] iwlwifi 0000:00:14.3: loaded PNVM version 881c99e1
[    5.041007] iwlwifi 0000:00:14.3: Detected RF GF, rfid=0x3010d000
[    5.106677] iwlwifi 0000:00:14.3: base HW address: 60:a5:e2:e8:20:f6
[    5.126126] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
 ls -l /lib/firmware | grep gf4
-rw-r--r--  1 root    root    1541932 Jul 26 03:35 iwlwifi-so-a0-gf4-a0-67.ucode
-rw-r--r--  1 root    root    1552216 Jul 26 03:35 iwlwifi-so-a0-gf4-a0-68.ucode
-rw-r--r--  1 root    root    1566352 Jul 26 03:35 iwlwifi-so-a0-gf4-a0-71.ucode
-rw-r--r--  1 root    root      28064 Aug 18 12:28 iwlwifi-so-a0-gf4-a0.pnvm
Kernel 5.14 it seems is what’s needed at minimum for 411/211.
Yeah, I've been running 5.19.x though.i tried loading 5.14-18 versions but had this weird no mac error. I think between deleting all of the ucode and pnvm files and hard booting it dislodged the issue because I copied in the ucode files and did a modprobe and the error indicated it wanted the pnvm file to activate and from there it was flawless again. There's sometimes odd issues that appear on soft reboots though that don't with a hard reboot.
Hello does the dct feature work on linux?
Do you need to have both bands use the same SSD?
Is there a manual/page from intel on how to set up this feature?
