darkshifty
Hi all,
I've recently purchased a AX4200 and replaced my ISP's router to improve VPN, however I bumped into two major issues.
One of them is that I opened a SFTP and HTTPS port as I did in my previous router but it doesn't seem to work
If I connect locally to 192.168.100.100 with port 4400 via SFTP it's working, if I try to access it remotely through my home IP
I receive the error:
I just can't seem to figure what is blocking the access, the firewall IPv4 and IPv6 are active but there are no rules that seem to block any access. If I disable the firewall I still receive the mentioned error.
I am using the original firmware: 3.0.0.4.388_32271
sftp -v -P 4400 user@xx.xxx.xxx.xx
ssh: connect to host xx.xxx.xxx.xx port 4400: Connection timed out
