Solved AX56U - Slow internet
You have Instant Guard available for travel purposes. It's very easy to setup and fast enough.
I installed "Instant Guard" to try it out and works well, I had a problem with port 500 and 4500 as I was already using them but this was a quick fix, my only gripe is it takes a while to establish a connection, around 20-30 seconds at times, other than that it works pretty well, I was able to access my network without any problems. I think I'll use this as a fail over until the Wireguard is sorted. Cheers mate.
