AX82U UK Save settings Backup
darshiz
Hi All,
I have an AX82U that currently has corrupt nvram (shows invalid country code, no wifi and all lights).
I am currently trying to restore it, but need a backup of the "save settings" file of a working model.
Therefore, would anyone that has a UK version of AX82U V1 not V2 be able to share a copy of your "save settings" file (Administration - Restore/Save/Upload Setting) over private message?
You can use the "Click on this checkbox if you want to share the config file for debugging. Since the original password in the config file will be removed, please do not import the file into your router." option to exclude any user names and passwords and avoid any security issues.
Thank you,
darshiz
Hi All,
I just wanted to check again if anyone was willing to share their save settings file.
Thank you,
darshiz
