Funnyland123
Hello everyone, I need your help or your advice because even my VPN provider has no advice.
First of all what I have already done.
factory reset
Current but also older Asus Merlin firmware
Asus AX86U original firmware
Different DNS addresses.
And almost every imaginable setting.
Whether static IP or automatic does not matter. I add the original DNS addresses from Nordvpn (my provider)
103.86.96.100 and 103.86.99.100 I get a DNS leak no matter on which server and in which country.
I wear for example
1.1.1.1 or 1.0.0.1 or Google or no matter what else there is I have no DNS leak.
When I asked Nordvpn, I heard it was the router, which I don't believe because the part is new and otherwise works perfectly. I should contact Asus. Well he will tell me to contact Nordvpn.
The funny thing is that the error only occurs with these 2 original Nordvpn DNS addresses and you should think that the Nordvpn servers and their DNS addresses work together.
Does anyone have any advice where it can be?
factory reset
I wear for example
