AX86U first time use questions
Thanks, I have set 5GHz to channel 36 at 80MHz but another small issue is how do I access the modem web UI for line stats (192.168.2.1) from the browser? The router's IP is 192.168.1.1
just a suggestion - while you're in there, you might want to change the modem's IP to 192.168.1.0 - it comes BEFORE the router, right?
also, it can't hurt to clone the modem's MAC to the router, if that's where you're doing the ISP authentication
