I get APIPA addresses when I try to connect a Windows PC to the LAN.Use the Asus Device Discovery tool to verify the IP address.
What happens if you disconnect it from you ISP device? Does it give you any address?I somehow cannot access the WebGUI for the router and it's kind of become a Wi-Fi repeater for my ISP instead of myself.
Is there a way to access the router WebGUI via LAN cable without factory resetting it?
That's the last resort,Might be a good idea to do a reset with the reset button or a hard factory reset. Plug the cable from the modem/ONT to the router WAN (1 GB) port and set it up again. Sounds like you tried to use the 2.5 GB port to the modem/ONT without proper config. If that is the case moving the cable to the WAN port may solve your issue.
and I got curious when selecting WAN type to 2,5 Gbit port instead of the 1 Gbit port
I have my AX86U connected straight the wall (Ethernet jack) with no modem in between my ISP and me other than the invisible backbone switches in between us.To me it sound like a router configured with 2.5GbE port as WAN (the red light), but the modem/router is connected to the Gigabit WAN port, now just a LAN port (the LAN IPs mess).
I got lucky to remember trying to be my own ISP. I ran a DHCP server on a Windows box wired to the 2,5 Gbit port in the router and could access it through sheer luck that I still had the https port open on the WAN side.
I figured out the LAN IP was not set to the usual 10.x.x.1 after switching back and forth between the router modes. It had taken the old WAN IP and put it on LAN NIC instead.
It's back to how it was before.
Welcome To SNBForums
