I have the RT-AX88U. I've set up my WiFi to use channel 100 for the 5 GHz network.
However, it's actually using channel 149, which is the single worst channel for it to automatically select (because all my neighbors' access points also selected 149). I'm determining the channel both from option-clicking my WiFi icon on the Mac and from airodump-ng on Kali.
How do I get it to *actually* use the channel I selected?
2.4 GHz Settings:
Hide SSID: No
Wireless Mode: Auto; NOT optimized for Xbox; b/g Protection
HE frame support: Enable
Bandwidth: 20/40 MHz
Control Channel: Auto
Extension Channel: Auto
Auth Method: WPA2-Personal
WPA-Encryption: AES
Protected Management Frames: Disable
5 GHz Settings:
Hide SSID: No
Bandwidth: 20/40/80/160 MHz
Control Channel: 100
WPA-Encryption: AES
2.4 GHz Settings:
Hide SSID: No
WPA-Encryption: AES
5 GHz Settings:
Hide SSID: No
WPA-Encryption: AES
