dornadeluxe
Hi all,
I have some serious issues with my AX88U, which I hope someone will be able to help me with here. To be honest, I am so frustrated that I am happy to donate anyone 20€ via PayPal who's able to solve my issue.
To my configuration:
I am using an AX88U as my primary router, which sits behind an Arris TG3442DE - Vodafone Station. Unfortunately the Vodafone Station cannot be used in bridge mode in the area in Germany I live, therefore I have a double NAT configuration. WiFi on the Vodafone Station is disabled.
In addition to the AX88U, I currently also own an AX58U, which is configured as AI mesh node and connected to the AX88U via LAN.
To the problem:
My router is crashing on an regular basis, sometimes several times a day, sometimes once in two weeks. On average I would say it happens twice per week and the symptoms are always the same. By crashing, I mean that I will lose internet connection every time and approx. 50% of the time I will even not be able to connect to the router via WiFi or LAN any more at all (seems like it also depends on the timing, it will lose internet connection first and then slowly loose all other connections as well). The only thing that helps, is turning the router off and then back on again or if it still accepts local connections a soft restart will also do.
I can actually "force" the problem to happen by moving to a room in my house which has pretty bad WiFi reception and then start streaming video from my iPhone. After a few minutes, it will drop the internet and then all other connections as well - although sometimes it will continue to work just fine. Also, it is definitely not only related to streaming video, sometimes the router will just stop working during night time when everyone is asleep and there are various other scenarios as well.
Everything is working just fine when the router is not crashing, I have no performance issues or other problems.
What have I tried already:
Looking forward to your ideas on how to solve this!
Thank you and best regards
Oliver
To the problem:
- I have reset the whole system and started from scratch setting it up - problem persists
- I have installed both the latest Merlin and the latest official firmware on both ASUS routers - problem persists
- I have exchanged the AC87U, which I have been using previously to extend my WiFi range, against the AI mesh capable AX58U - problem persists
- I have now bought a brand new AX88U a few days ago, since in the end I believed it would be a hardware issue. I set it up as a completely new router - and the problem still persists!
- June 13th, crash at approx. 20:10 (merlin) -> 1st AX88U
- June 14th, crash at approx 6:50 (merlin) -> 1st AX88U
- June 14th, crash at approx 8:24 (merlin) -> 1st AX88U
- June 14th, crash at approx 10:00 (merlin) -> 1st AX88U
- July 13th, crash at approx 7:12 (merlin) -> new AX88U
- July 17th, crash at approx 9:00 (original ASUS) -> new AX88U
Oliver
