AX88U Nordvpn Wireguard Adguard Problem
Funnyland123
Hello, I use the latest Merlin version on my AX88U.
I use Nordvpn wireguard (see pictures with the settings)
Wireguard is doing well. Now I wanted to test Adguard, but I have the problem that although DNS requests are in the statistics, they are not blocked. I have the same problem with Diverson. (do not run simultaneously)
If I switch off Wireguard, the DNS requests shoot up and requests are blocked.
If I use OPEN VPN, DNS requests are blocked.
Anyone have an idea where the error is?
So I found that the problem is related to Wireguard and I have Local IP 192.168.50.1/24 or 192.168.50.0/24.
Do I only make an IP eg. the imac is fine
Symbol „Von der Community überprüft“
