T_William_N
I've just bought a QNAP and I want to backup folders on my PC to NAS (it will be on a different network, 300 km away), the problem is that I can't use NetBak Replicator because of the unwanted path on the QNAP and this artificial path render the backup useless for my intended purposes.
I always use the ones that don't create unwanted paths, like FreeFileSync or Syncthing but I've only used those to backup to External Harddrive, never to a NAS on a different network.
I don't have the knowledge of use FreeFileSync or Syncthing to backup to the QNAP on a different network will need to be explained in detail and step by step or if there is any way of making NetBak Replicator behave normally and not create artificial paths that would also be a viable (actually preferable) solution.
Also, I have some long file paths, So I would like to have the ability to copy long pathname (260+ characters) and to have it run on schedule without you having to worry about opening the app or not, and I need a way to have it email me or notify me so that I will know it is always running on time.
I am ensuring if I will have these features or not while backing up to QNAP !! Also, any suggestions for alternatives are welcome but to be something easy and quick.
thanks in advance
thanks in advance
