Bad UI Design Sabotages Security of ASUS SoHo Routers
And yet, CTF provides a major performance improvement when you bypass the FORWARD chain (among other undocumented things).
Latency improvements?
CTF confuses me with it's initials corresponding with the latency-improving "Cut-Through Forwarding", but I don't think that is correct.
Well - CTF.ko does odd things and Broadcom doesn't let anyone see behind the curtain (even with NDA in place...)
No, you're correct - Cut Thru Forwarding - basically I'm told that it sets some tags inside the switch functional block inside the Broadcom System on Chip... note I say functional and not physical - the switch element inside the Broadcom SoC's is much more than a general unmanaged switch - and in the immortal words of Forrest Gump - "That's about all I have to say about that"
When I first heard of cut-through forwarding, the name didn't make sense. Then I realise it's very indicative of its functionality. Much better than SmartXXX or IntelliYYY from other companies. lol. It's really cutting through the protocol stack..in its cruelty. When it works, it's very nice.
Unfortunately now it seems break here and there. Turning off CTF becomes a band-aid to every single mystery connection/performance issue. On top of that the CTF implementation looks improved on newer SDK (so, good for you new router owners) but only bug fixed in older ones.
Netfilter or rather the current stack in Linux is showing its age. In multi-gigabit era, we need something better and some are horizon already..
That's another alarmist report. Because if you disable that firewall, you are exposing MUCH MORE than just your router's webui... Like, uh, your whole LAN.
"Sabotage"? Some wannabe security experts need to get a life, quite bluntly.
Are these people serious? I have owned routers from Netgear, Speedtouch, the newer Technicolor, Fritz!Box, and Draytek as well as Asus, guess what, they all had a button which said Firewall on/off.
This is on a par with the "technical review" I saw written by a so called expert for one of the PC magazines.
The "expert" was reviewing Private Firewall and slammed it because " I let the kids surf the net for a few hours, the firewall failed our tests because when we looked it had allowed cookies to be installed to the machine from the internet". ......... Yeah, okay.
I'm glad to be reminded of this, it's not something obvious. You'd think if one turns the firewall off, the firewall settings are still enforced that block access from the WAN if the "allow WAN access" button is off. I'm not sure why people are getting offended at the reviewer. I think even intelligent consumers would assume that part of the firewall that controls WAN access, the IP tables, are still valid no matter the state of the firewall button. I think it is an under-sight from ASUS.
FWIW - While I never depreciate security considerations...
While the SPI firewall that the guy reported might get accidentally disabled, one is still NAT'ed, which is a firewall of sorts in and of itself... tempest in a tea-cup perhaps?
I'm surprised nobody brought that up...
Anyways, the take-away here is that there are many levers and switches that can lead to a misconfiguration and potentially expose your network - and that's the big thing to take away from the "disclosure" that started this thread...
NAT protects the LAN, but it does not protect the router itself, which is what the article is about.
I have wondered if NAT was vulnerable to some sort of attack. Disabling firewalling is still ill-advised, especially for gateway routers. Better safe than sorry.
Edit: I am torn between presenting settings and hiding them, because I know how bad I am with "if there's a switch, I must flip it"... like all defaults are conspiratorially sub-optimal.
NAT itself is fairly safe in an IPv4 context...
There's always concerns about NAT gateways - e.g. SOHO consumer router/AP's - as they are vulnerable - not the first time, and it won't be the last... these things have a lot of old code, and many will never be fixed...
Armand28 37 bad PEBs on an AXE16000 ASUS Wi-Fi 7
H Asus Network design ASUS Wi-Fi 13
