Bash Loop Error
Col8eral
Try to run a simple loop script
#!/bin/sh
max=10
for (( i=2; i <= $max; ++i ))do
echo"$i"
done
but im getting "syntax error: bad for loop variable" when I run it. Wht am I doing wrong?
Thanks.
#!/bin/sh
max=10
echo"$i"
done
Thanks.
Just a quick clarification. Our routers use POSIX, not Bash. (You can enable it if you so choose, but it gets more messy). POSIX shell has issues with advanced loops like this... you probably want to use something like this:
i=0
while [ $i -le 10 ]; do
    echo "$i"
    i=$(( i + 1 ))
done
Thank you. I tried that and got this error:
loop: line 7: syntax error: unexpected end of file (expecting "do")
Make sure you set the environment at the top:
#!/bin/sh
i=0
    echo "$i"
    i=$(( i + 1 ))
done
exit 0
This works for me:
Not sure what i'm doing wrong
Are you copying and pasting from a Windows notepad window by chance? Or some other intermediary source? I have heard of instances where additional hidden characters will mess with the script. Try copying it from here, and pasting it directly within nano (right-click on your mouse while in nano)... then save it. See if that helps?
