getop long options not work
pseu_asus
Hi, all,
I have a simple script where I would like to use getopt long option, seems it can't work on ASUSwrt, do you have any idea?
Here is the simplified script:
Bash:
#!/usr/sh
args=$(getopt -l us,ca,mx,misc -- "$@")
if [ $? != 0 ] ; then echo "Terminating..." >&2 ; exit 1 ; fi
eval set -- "$args"
while :; do
case "$1" in
        --us)
            echo "us"
            shift;;
        --ca)
            echo "ca"
            shift;;
        --mx)
            echo "mx"
            shift;;
        --misc)
            echo "misc"
            shift;;
            echo "--"
            shift
            break
            echo "??"
            shift
esac
done
If I change the getop to "-o ucmo", then in the do case use the one-letter options, it works.
As far as I can tell to be able to use the long options it's mandatory to also define at least one short option (even if you ignore it).
P.S. Line 1 is an error. It should be #!/bin/sh
#!/bin/sh
args=$(getopt -l us,ca,mx,misc -o ucmo -- "$@")
eval set -- "$args"
while :; do
case "$1" in
        -u | --us)
            echo "us"
            shift;;
        -c | --ca)
            echo "ca"
            shift;;
        -m | --mx)
            echo "mx"
            shift;;
        -o | --misc)
            echo "misc"
            shift;;
            echo "--"
            shift
            break
            echo "??"
            shift
esac
done
Thank you. I'd seen this earlier today and haven't the chance to mess with it yet.
I recall the few times over the years that I've opted for "getopt" it was too arcane, and usually use "for i in $@; do case $i in; ....; esac; done" instead.
Gotta say that from the values of the options here, either a language or radio settings are the goal, and the latter really aren't useful these days...
