BE88U Static Route
Erah
I'm trying to set a static route to access the WAN web interface but it doesn't seem to work.
I can only get it to work by setting a static WAN IP.
Any ideas?
This makes no sense. You don't need any routes to access directly attached network interfaces.
If you want to access the router's web interface from the internet you use the option under Administration - System. This is strongly discouraged for security reasons. You should be using the router's VPN server instead.
