BE98 Pro (AX Only Option)
tebtengri
Under the professional tab for the various frequencies there are options for wireless mode. I'm mostly interested in 6GHz and maybe 5. There are options for Auto, AX Only, N/AC/AX Mixed and Legacy. I find it odd there is no "BE Only" option on any of them.
My question stems from this lack of BE Only option - Does AX Only actually include 802.11be? Or is it literally as it says, AX Only? I'd like to have one of the 2 6GHz networks be 802.11be only if possible, but AX+BE works too, assuming that is what the "AX Only" option enables.
Anyone have any idea? I can't remember for sure, but I had a Wifi 7 TP Link I got from Walmart waiting on the BE98 Pro to arrive and I want to say it had a be only option. Asus have any plans to add this:?
Leave the setting on Auto. Only Wi-Fi 6E and Wi-Fi 7 devices can use 6GHz band anyway.
Asuswrt firmware has quite a few copy/paste errors and general lack of dependencies. You can have contradicting settings and incorrect help tooltips. If this thing is about 6GHz radio - ignore everything else except Wi-Fi 6E and Wi-Fi 7 related. The more curious you are the more bugs you'll discover. Just use your router and don't pay too much attention to details. The firmware is always in work-in-progress state. Report to Asus in Feedback Form major bugs and inconsistencies you discover for a chance to see better Asuswrt further down the road.
If you toggle the Enable WiFi 7 it accomplishes the BE only, I believe, because it enables 320 MHz bandwidth AND AES+GCMP256 (256 bit encryption).
