Might want to look into https://www.gl-inet.com/products/gl-mt6000/ though this likely won't be the place to come for support. Looks like (claimed, anyway) pretty good VPN performance.
Perhaps someone can give you the actual VPN client download speeds they are are getting on the same model that you are planning to purchase. On my AX86S the download speeds I get range between 160 - 180 Mbps but occasionally slightly higher. This is only a little higher than I was getting on my AC86. If you have devices that you want to get higher VPN download speeds on you probably will need to run the VPN on the device with a more robust processor than most routers have.Thanks for the feedback. Actually, anything close to 600MB would be great, as I currently get only about 50 MB on my current DDWRT router. Plus, as the 86U is a WIFI6 router, if I understand correctly, my compatible devices will also be able to take advantage of that speed. As for the 2Gbit speed being a waste, when I connect directly to the modem via wifi, I get superfast speeds, which is awesome, but again, I need a new, faster device specifically for the VPN I can use, so I think the 86U *should* be a great choice, hopefully!![]()
An TP-Link Archer C9 running some version of DDWRT.What router do you have currently?
Haha, yes, exactly!WireGuard only and up to. I believe the OP is talking about AstrilVPN or similar.
With all new Asus hardware moving (slowly) to 3.0.0.6.xxx level firmware sooner than later, buying an RT-AX86U today is not a good use of funds. That model won't get the latest firmware (as has been mentioned here on these forums by many, including RMerlin himself).
Can you afford to buy something that may need to be upgraded in the next year or so? And effectively cost you 150% or more of something worth buying today?
The GT-AX6000 and/or the RT-AX88U Pro are the best bang for the buck choices today. The latter may have the edge for longer support too, because it was announced well over a year after the GT-AX6000 model.
What is your current router? Is it an AC class model?
To get closer to true 2Gbps speeds over WiFi, a WiFi 6E or a WiFi 7 model router is needed. However, both those class levels are not the value options, today. But letting you know what hardware will be needed to actually give ~2Gbps wireless. (i.e. it's not only the WAN 'input' Port that determines this, it is the RF hardware too).
Haha, yes, exactly!
That TP-Link Archer C9 was an entry-level AC class router, at introduction. It is also EOL today.
AC1900 Wireless Dual Band Gigabit Router
Archer C9 provides decent dual band Wi-Fi and boosts your experience great for entertainment and 4K streaming on multiple clients.www.tp-link.com
The two models I suggested for you (GT-AX6000, and RT-AX88U Pro) are playing in a different league over what you have today. Highly recommended over the RT-AX86U and/or 'pro' models.
Again, your choice is basically this;
do you buy something to simply match (as closely as possible) your ISP capabilities today and save a bit of money, but know you will only get a fully supported router for a very short time (RT-AX86U),
or, do you buy something that is supported a bit longer (RT-AX86U Pro), but still has unbalanced hardware that will be worth less when you do decide to move to WiFi 7 (or better),
or, simply buy today the more hardware balanced, supported for much longer, and will be much more useful to you as (not if) your circumstances change (or, even if you just want to sell it at that future time)?
Hope I'm explaining well the choices you're actually making here. Good luck.
Merlin is not "in Beta". Merlin uses GPL's provided by Asus and offers both final release versions, and often a "alpha" or "beta" version of the next compile or update for people to test with before that version goes final release.Merlin also seems to still only be in Beta, which would definitely be an issue.
That was a great write up, thanks!
I looked over the specs of the 88U Pro, and it doesn't look as if it offers much more than the 86U Pro. Merlin also seems to still only be in Beta, which would definitely be an issue.
So I might still go for the 88U Pro. Just need to confirm with the VPN guys if their applet supports the Pro model.![]()
Welcome To SNBForums
