Best and most optimal settings (Voxel & Kamoj)
Yep, I see this post ;)
Rules look fine to me, and if it works, then you know it is fine :)
You probably could simplify them by detecting the port (53 for DNS).
Something like
iptables -t nat -A PREROUTING -i br0 -p tcp --dport 53 -s ! 192.168.1.2 -d ! 192.168.1.2 -j DNAT --to-destination 192.168.1.2
iptables -t nat -A PREROUTING -i br0 -p udp --dport 53 -s ! 192.168.1.2 -d ! 192.168.1.2 -j DNAT --to-destination 192.168.1.2
This would redirect all DNS traffic from LAN to your PiHole, whatever the dns server.
Where would I place these rules? The /overlay/opt/scripts/firewall-start.sh doesn't let me write to it with Vi.
Absolutely, when I vi firewall-start.sh and try to :wq, it gives me a "Write error: Permission denied",
normally, you wouldn't touch stuff in the /overlay partition directly.
You would just make your modifications in /opt/scripts/firewall-start.sh and let the overlay-fs driver create the file.
Which device are you using?
Is the overlay-fs enabled?
On RBR it isn't by default. And if you then try to create a new file in /overlay/opt/scripts/firewall-start.sh, then that folder would probably not even exist and be read-only.
