Hi, all. Apologies if this is the wrong forum group to post in; I didn't know which one to post in as it's about an AX3000/58U as well as AC86U's.
I'm currently setup with 3 x RT-AC86U's with one acting as a primary router and the other two setup in mesh mode as the internet connection comes in on one end of our house. The first mesh node connects via 5G to the main router, and the 2nd mesh node connects (via 5G as well) to the first mesh node; essentially, they're chained in a line to each other. My internet connection is less than 1GB, and I'm only using 1 LAN port on the main router. I've usually got 35-40 active wifi connections at any one point (3 kids! lol) and I'm using Merlin firmware.
I had a buddy of mine upgrade his router and I've now got an RT-AX3000 (AX58U) I can use in the house. I've done some research on the AX standard potentially providing better connectivity to more devices but I'm not sure if that really applies to the 86U's in mesh mode as they're not AX capable. The 58U also has a tri-core processor vs. the 86U's dual core, but both models have the same 512MB of RAM.
Side note - I'm pretty interested in running native SNMP on the main router for monitoring purposes, but that's not a must-have. The 86U's only support the mini-snmpd, but I'd prefer to use full SNMP + extensibility that the 58U can do.
My question - any thoughts on using the AX3000 as the primary router and the 86U's as mesh nodes, or should I just throw the AX3000/58U on the network as another mesh node?
