flamaest
Hello all,
I am looking for the fastest dlink wireless solution when running a mixed 2.4Ghz N/G/B (20MHz) network, with all clients at around 50 feet. I will be moving things to N/G once the router is selected [and tossing the B clients].
Some requirements in selecting the best solution:
-1 Client: must be PCMCIA: DWA-652
-1 Client: must be USB 2.0: DWA-160
-1 Router: must be fastest at 2.4GHz, don't care about 5Ghz.
-20MHz bandwidth
-Encryption: whatever supported by clients.
So, the question boils down to: Which DLINK router should I get: the 1522, 655, 825, 855, or 685 ?
I don't care about the price, just want max performance/distance out of the box.
Thanks,
Fabian.
-20MHz bandwidth
Thanks,
Fabian.
