I posted this over at the Synology forum but have not yet received a response. Perhaps some people here in this forum could help me out?
Hi -- I currently have a very small business where we have a Windows Home Server (WHS) acting as the main backup server and fileserver. We also use it to archive all old projects, for easy recall later on. For the number of computers we use, it works pretty well (less than 10 on the network). That server has folder duplication (so the shares are mirrored) and then all that gets backed up to an external fireproof hard-drive, so we have multiple copies. This has been a pretty good solution for us so far.
However, due to the death of Windows Drive Extender (Microsoft canceled this feature in the next version of Windows Home Server, which was one of the dumbest decisions I've seen in this market), I've decided to slowly migrate off this server onto one or more NAS devices -- no need or desire to invest any more time or money into Windows Home Server. The biggest thing that bothers me about Windows Home Server (besides the fact that Microsoft canceled Drive Extender), is that if the boot drive fails, then the whole server is down and needs to be re-installed from scratch. THAT is a major pain in the neck for me. Right now, the server occasionally behaves a little strangely and also has inconsistent performance, so all those things make me a little uneasy and I know have to take some action.
Synology jumps out as the obvious candidate to replace the WHS box. I've also looked at QNAP, but I like the Synology software better, so I'm pretty sure I'll be buying Synology.
So, this is what I need to figure out, and I'm hoping some experts here can help. I don't consider myself an IT expert, so any advice you can give will be greatly appreciated.
First, there are three classes of data we have:
1) Daily computer backups (often an image of the boot drive of various computers on the network)
2) Active project data (shares which hold tons of video, images, documents, etc.) so we need a lot of space
3) Long-term ARCHIVE data (which is data we never want to delete, like old projects and documents), also need ton of reliable, cheap, long-term space, but optical media isn't large enough any more and is too much of a hassle. So we're sticking with copies of archive materials on hard drives. Plus, it's quite common that we need to resurrect a project from 1-2-3 years ago and bring it back online quickly, so hard drives make sense.
So, what type of configuration should I get, and what type of migration plan should I implement?
I am not opposed to getting 2 separate NAS boxes for different tasks.
For the tasks above, 1+3 don't need high performance, since they are most often one-way storage and backups/archives can happen unattended.
For task 2, I would like slightly faster performance since we access that data frequently.
So I was thinking of getting two NAS boxes. One for tasks 1+3 and one for task 2. This could be part of the "migration" plan so I could buy one NAS box now, and migrate one or two tasks off the WHS, and then buy another NAS box later to finish the transition.
Now, I already realize I need to backup both NAS boxes if I buy two. So I'm wondering what the best approach would be? Should I use something like rsync and just sync the two boxes together? Or should I use an external USB drive as the NAS backup? A combination of the two? And frankly, all that data needs to eventually go on one or more fireproof hard drives for extra protection.
Thoughts? Recommendations?
Can I do all this on one larger NAS? Or should I get just two smaller ones?
Also, I'm not convinced that RAID-5 is a good solution. It seems like RAID 1 or RAID 6 would be better for my case for data protection... with RAID 5, one drive failure would be dangerous and put me at risk until I rebuild the array. I'd rather minimize the impact of a single drive failure by doing straight mirrors or at least allowing for two points of failure (RAID 6). ..... OR should I not worry about using any RAID 1, 5 or 6 AT ALL if I'm planning on rsyncing, or using external USB drives as backup? Why not skip RAID altogether and just do single drives, as long as I have backups/rsyncs?
Also, do you have any suggestions of how to gradually migrate off my current WHS system... maybe do it in steps? Move one task at a time to one or more NAS boxes?
Finally, keep in mind this is a very small business, which means I need to control the costs carefully! I wish I had a large budget, and I'd just buy 3-4 big NAS boxes for different tasks, but I have to keep things consolidated, simple and cost-effective.
Thanks in advance for any advice you can share.
