I was planning to buy a Drobo but after reading here I am hesitating.
What I like about the Drobo
Main usage would be to store growing Aperture Library but then I would have to get a good performance to edit photos stored on the external disk.
Currently Drobo promises the following:
A few questions I have:
Network acces is a plus but not a must have. Do you advise a local attached disk (firewire/USB) or NAS for performance issues?
Have had a look at charts here but as there is no data about Drobo or local attached drives I am stuck here. I am looking for the best mac-compatible solution.
Thanks for the advise!
- Storage grows as you need, no need to fill the device with x equal drives from start.
- Mac compatibility (time machine)
- Ease of use
- FireWire 800: Up to 52MB/s reads and 34MB/s writes
- USB 2.0: Up to 30MB/s reads and 24MB/s writes
- Are there other brands out there that offer the "growth" functionality like Drobo?
- If the disk fails, I just replace the disk. If the controller fails, I have to replace the Drobo. How is this with non proprietry RAID systems? Can you rebuild disk from a failed Synology controller in a device of another brand or do you always have to replace a failed controller by the same brand/type in case disaster strikes?
