Entware best way to transition from AC87 to AX86?
al cons
Hello, I am in the process of setting up a new router (RT-AX86u), and want to know if I can simply transfer my flash drive from my old router (RT-AC87u) and have all of my entware addons work? Is there a suggested protocol for this other than starting anew?
thanks,
A-
thanks,
A-
Would recommend to start anew, think the ax86u supports a newer entware (64bit).
Backup the drive, maybe can use some custom entered settings after and manually re enter them if needed.
