XIII
Part of the Furniture
I hope you don't mind me asking, but what's the purpose of these placeholders?Why is there two persons who "liked" the placeholder post?![]()
I see. I'm gonna have to test smb2.Stock firmware does not support SMB2 at all.
I kept it disabled by default after adding support for it because of the performance impact it has on these weak CPUs.
Sent from my P027 using Tapatalk
Try loading the required modules with modprobe first. I remember a similar issue used to exist in early days, until I added a modules.dep config file. If manually loading the modules work, then it means the issue is probably with the modules dep file.
The original support was a direct port from Tomato-Shibby.
The only thing I'm aware of that's not working is the 'extended' qualifiers when creating an ipset...skbinfo, comment and counters. (Also doesn't work on the current level). When I started to research it, I found references that these were related to linking to the kernel headers and may not work on early kernel levels. I haven't pursued it beyond that.
What device?Running much better than 380.66_6 ... My fios would sometimes show the full 980 Mbps down and sometimes it would be around 400 Mbps... Since switching to 380.67 beta everytime I run speedtest I get around my 980 Mbps down... seems to be much more stable in the few hours since I flashed it too.
Hopefully support can be added, comments on ipset entries would be a huge plus for keeping track of large sets.
I'm probably forgetting something... What?
I am unable to set a custom QoS priority (the ranking of what traffic is used most) on my RT-AC88U using the beta 1 of 380.67.
This makes me believe that asus have better integrated HW support from some of their vendors rather than others.
Based on this, if my RT-AC68 dies tomorrow, can you suggest either a metric or hardware feature I should look for in a new asus router to continue getting the best support (from merlin fw, that is gives you the least hassle integrating the source)?
Adaptive or Traditional QoS?
Did you delete all the old certificates? Firefox is trying to match all the certificates, if you have more than one for the same IP address stored. So it could be an old certificate. Go to the certificates manager in Firefox: Options - Advanced - Certificates - View Certificates - Servers - 192.168.1.1:8443 or your IP. - Delete all of them.I have copied my self-signed certificates (which were already in /etc) to /jffs/https and rebooted.
However Firefox still complains about an Insecure Connection when accessing https://router.asus.com, while I have imported the certificate in Firefox.
I also had this problem with 380.66_6, while the certificates worked before (and they won't expire for a long time).
Welcome To SNBForums
