Yeah, the iPad Air 2 disconnects here too. I should have been clear. When I said 5Ghz hasn't crashed I meant literally that - radio goes off the air and router needs a reboot, that was what was happening on Merlin .55 and .54. It's a bit early to say as sometimes it could take 2-3 days for the crash, but normally it was within 24 hrs, so looking hopeful.
Still, though, as we have discussed elsewhere, although I am sure the disconnects are down to something Apple have done, I don't think it is affecting other 5Ghz wifi chipsets or we would be hearing more complaints. I think this is a change that Quantenna should be able to deal with and are not.
Matil did you just check the number on the GUI or attempted an actual large file transfer?The feedback to Asus feature in the GUI did not work, perhaps something needs to be configured (like a mail server)..
I saw the same speed on my laptop and ran a speed test against speedtest.net, the result was not so impressive..Matil did you just check the number on the GUI or attempted an actual large file transfer?
I saw the same speed on my laptop and ran a speed test against speedtest.net, the result was not so impressive..![]()
There was nothing restoring by itself, a router reboot was necessary to get back to normal operation.well it's quite normal for the link to degrade or rather power save and then restore full throughput on demand...
5Ghz battery drain issue for Android devices is still present.Good Morning
1. Where is scheduler for Reboot ?
Release note typo. Will release one beta firmware later for you.
2. For "Web History/Traffic Analyzer can show device name" also should add option to save data for external storage or internal to user still have data after restart router. I want control my children but when router reboot when i am in work , then i have no data.
Devices should be seen after router reboot, did you remote login to ASUSWRT and check the Web History/Traffic Analyzer?
3. You tell me that Green Icon for VPN will be add but not added.
Could you explain for me again about the Green Icon, i didn't get the information.
4. Should be add option edit forwardig port on WAN without delete. Now when user want edit port, user must delete port and again add wit new set. I think good is the same style as styl edit client![]()
we have plan to do this.
5. Good option is add to NETWORK MAP on tab STATUS display info about temp CPU and temp WIFI 2,4GHz and 5GHzlooks good with data use core and memory.![]()
Thank you.
6. And i please and send you file with setting for Polish provider AERO2 and please to add to configure USB GSM. Now still not added
Can you help to send the 3G/4G log by Administration->Feedback?
7. BIG BIG BIG BUG !!!
In TRAFFIC ANALYZER>STATISTIC when i see on Today is OK i have statistic for client and in list i see clients. When i set date two day ago... i also see but when i come back to today i dont have client in list... and show other data before i set two day ago. Daily traffic is other... When i go to other menu and then come back to TRAFFIC ANALYZER>STATISTIC all is ok. But to time when i set other day. VERY VERY VERY BIG BUG and still is from some version firmware.
We are looking into this issue.
8. When ASUS correct finally DUAL WAN with USB 3G GSM ? Because it still not working correct.
Although the new 5GHz driver can improve 5G Disconnection issue, we found it will cause battery drain for Android devices.5Ghz battery drain issue for Android devices is still present.
Good Morning
Thank you.
I want to thank whoever you are for taking the time to register here and comment. It is much appreciated. If you're an individual, you should be promoted, if its a company idea...kudos to Asus.Although the new 5GHz driver can improve 5G Disconnection issue, we found it will cause battery drain for Android devices.
Already forward this to QTN for new SDK.
mDNSNetMonitor is Apple's Bonjour.These errors are nasty. Whatever the problem causing these errors needs to be fixed asap. Because when it occurs, the router becomes totally unresponsive for a few seconds.
Sep 28 09:48:18 mDNSNetMonitor: GetLargeResourceRecord: opt 65002 optlen 8 wrong
Sep 28 09:48:21 mDNSNetMonitor: GetLargeResourceRecord: opt 65002 optlen 8 wrong
Sep 28 09:48:30 mDNSNetMonitor: GetLargeResourceRecord: opt 65002 optlen 8 wrong
Sep 28 09:50:25 mDNSNetMonitor: GetLargeResourceRecord: opt 65002 optlen 8 wrong
@Asus - Fix this problem
Good Morning
Thank you.
Welcome To SNBForums
