nyxagamemnon
Okay,
So this router is literally driving me insane with it's issues and I'm wondering if there's any solutions.
#1) I will have to reset my cable modem (Not from ISP I bought myself it's a Motorola SB6120) Like 50 times and go through the Asus Wan setup and it won't detect it over and over and over and over till the point that on 1 reset it will detect it and then NO ip and I have to repeat this over and over. I Tried this on ANY OTHER Router IT WORKS with just 1 reset perfectly on the R7000 and any of the other routers I have.
#2) WAN will randomly loose it's IP Address and then force me to go through my first problem 50 times before it detects the wan again.
#3) I will turn the lights off on the router and when these issues come up lights will just turn back on by themselves even though the button is set to off.
I have tested an R7000 no issues 1 reset of the modem to pair with the new router works flawless and never drops my connection.
I have also bought another RT-AC68R does the same thing. This is on firmware 339 for both. It did this with the 374 version of the firmware as well.
Any solutions??
Any solutions??
