Alek
Is it possible to extend the range of a USB Bluetooth adapter using a 2.4GHz antenna? Specifically, can I scratch off the tiny antenna on the PCB (at least I think that's the antenna) and solder a connection to an external antenna? Is this a good/bad idea?
This may not strictly be the correct place to post this, but it is about wireless and 2.4GHz antennas! Also didn't know where else to ask and you guys seem like you might be able to give me a good answer.
