retrodroid
Hello all,
Apologies as I know this has been mentioned before.
I've read many posts and seen contradicting information.
I'm running the latest Merlin FW (3.0.0.4.354.29 Beta 1) and through the GUI have set a firewall rule to allow UDP 9 to broadcast on the LAN but it doesn't seem to work even though the GUI allowed it.
I assume adding the firewall rule also sets the required NAT policies? I'm used to SonicWall devices but my home ISP (Sky) require a specific DHCP command which SonicWall do not support.
However, I purchased the RT-N66U router and installed the Merlin FW (btw, enormous thanks to RMerlin!).
If it is possible, would someone mind detailing the steps required to allow a broadcast rule to be set?
The rule is to allow WOL from WAN to LAN through UDP 9. My internal PC has a reserved DHCP entry which I assume adds a static ARP?
If I cannot do this through the GUI, is it possible via the console?
Thanks v.much in advance
Bob
Bob
