Hitwomanforrent
Upon upgrading to Asuswrt Merlin 388.1, there seems to be a visual bug on the web interface showing Ethernet backhaul as lacking connection, when the link appears to function as normal. I'm using two RT-AX86U's, one as a node, both running 388.1, on "Ethernet Backhaul Mode." This appears to simply be a UI problem, and I've not encountered problems connecting to the node on clients, nor does there seem to be any impact on speed.
