SystemF
ASUSWRT: 3.0.0.4.382.15850
ISP: Vivacom BG
Select ISP Profile - None
Choose IPTV STB Port: LAN3&LAN4
Use DHCP routes : Disable
Enable multicast routing (IGMP Proxy): Disable
Enable efficient multicast forwarding (IGMP Snooping): Disable
UDP Proxy (Udpxy): 0
When downloading torrents the IPTV lag and freeze at some moments, tested with Asus offical and Merlin,
With Manual IPTV Settings from my ISP:
Internet: VID-2328 - Prio 0
LAN port 4:VID: 536 - Prio 4
LAN port 3:VID: 536 - Prio 4
I have not either internet or iptv gives me an error: "Your ISP DHCP does not function properly".
I notice that Lan port 3 is set by asus for VoIP with manual settings, i don't use voip probably bug, will
wait the new firwmare.
ISP: Vivacom BG
