[BUG report] AC86U: USB 3 SSD Drive doesn't mount (connected before boot)
Radiant
After booting/rebooting AC86U my Orico SSD USB-C Case (JMicron Generic) connected in USB 3.0 mode doesn't mount, only manual reconnection works well. USB 2.0 mode of USB 3.0 port or USB 2.0 port works well too. Original ASUS ROM works fine with this case in USB 3.0 mode. Help me please!
Thank you for advance!
Contents of System Log?
Jun 28 13:41:02 ntpd: Initial clock set
Jun 28 13:41:02 rc_service: ntpd_synced 1262:notify_rc restart_diskmon
Jun 28 13:41:02 disk_monitor: Finish
Jun 28 13:41:03 disk_monitor: be idle
Jun 28 13:41:03 miniupnpd[1276]: HTTP listening on port 42185
Jun 28 13:41:03 miniupnpd[1276]: Listening for NAT-PMP/PCP traffic on port 5351
Jun 28 13:41:03 kernel: HTB: quantum of class 10001 is big. Consider r2q change.
Jun 28 13:41:03 kernel: HTB: quantum of class 20001 is big. Consider r2q change.
Jun 28 13:41:03 kernel: HTB: quantum of class 10009 is big. Consider r2q change.
Jun 28 13:41:03 kernel: HTB: quantum of class 20009 is big. Consider r2q change.
Jun 28 13:41:03 dhcp_client: bound 10.153.30.190 via 10.153.30.185 during 86400 seconds.
Jun 28 13:41:04 kernel: usb 3-2: device descriptor read/64, error -110
Jun 28 13:41:04 kernel: usb 3-2: new high-speed USB device number 3 using ehci-platform
Jun 28 13:41:05 dnsmasq-dhcp[776]: DHCPDISCOVER(br0) 3c:28:6d:25:50:a3
Jun 28 13:41:05 dnsmasq-dhcp[776]: DHCPOFFER(br0) 192.168.1.18 3c:28:6d:25:50:a3
Jun 28 13:41:05 dnsmasq-dhcp[776]: DHCPREQUEST(br0) 192.168.1.18 3c:28:6d:25:50:a3
Jun 28 13:41:05 dnsmasq-dhcp[776]: DHCPACK(br0) 192.168.1.18 3c:28:6d:25:50:a3
Jun 28 13:41:06 kernel: nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
Jun 28 13:41:09 kernel: usb 3-2: device descriptor read/64, error -110
Jun 28 13:41:17 kernel: ubi1: attaching mtd9
Jun 28 13:41:17 kernel: ubi1: scanning is finished
Jun 28 13:41:17 kernel: ubi1: attached mtd9 (name "misc1", size 8 MiB)
Jun 28 13:41:17 kernel: ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
Jun 28 13:41:17 kernel: ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
Jun 28 13:41:17 kernel: ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
Jun 28 13:41:17 kernel: ubi1: good PEBs: 64, bad PEBs: 0, corrupted PEBs: 0
Jun 28 13:41:17 kernel: ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
Jun 28 13:41:17 kernel: ubi1: max/mean erase counter: 3/2, WL threshold: 4096, image sequence number: 1960956644
Jun 28 13:41:17 kernel: ubi1: available PEBs: 0, total reserved PEBs: 64, PEBs reserved for bad PEB handling: 4
Jun 28 13:41:17 kernel: ubi1: background thread "ubi_bgt1d" started, PID 1380
Jun 28 13:41:18 kernel: UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "nvram", R/O mode
Jun 28 13:41:18 kernel: UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
Jun 28 13:41:18 kernel: UBIFS (ubi1:0): FS size: 5840896 bytes (5 MiB, 46 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
Jun 28 13:41:18 kernel: UBIFS (ubi1:0): reserved for root: 275879 bytes (269 KiB)
Jun 28 13:41:18 kernel: UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 700E756D-208E-4C91-B256-B51AA3EDE77F, small LPT model
Jun 28 13:41:18 kernel: UBIFS (ubi1:0): un-mount UBI device 1
Jun 28 13:41:18 kernel: ubi1: detaching mtd9
Jun 28 13:41:18 kernel: ubi1: mtd9 is detached
Jun 28 13:41:20 admin: Could not start Entware
Jun 28 13:41:25 kernel: usb 3-2: device descriptor read/64, error -110
Jun 28 13:41:25 kernel: usb 3-2: new high-speed USB device number 4 using ehci-platform
Jun 28 13:41:35 kernel: usb 3-2: device not accepting address 4, error -110
Jun 28 13:41:35 kernel: usb 3-2: new high-speed USB device number 5 using ehci-platform
Jun 28 13:41:37 crond[784]: time disparity of 603696 minutes detected
Jun 28 13:41:46 kernel: usb 3-2: device not accepting address 5, error -110
Jun 28 13:41:46 kernel: usb usb3-port2: unable to enumerate USB device
Jun 28 13:41:46 kernel: usb 4-2: new full-speed USB device number 2 using ohci-platform
Jun 28 13:41:51 kernel: usb 4-2: device descriptor read/64, error -110
Jun 28 13:42:07 kernel: usb 4-2: device descriptor read/64, error -110
Jun 28 13:42:07 kernel: usb 4-2: new full-speed USB device number 3 using ohci-platform
Jun 28 13:42:12 kernel: usb 4-2: device descriptor read/64, error -110
Jun 28 13:42:27 kernel: usb 4-2: device descriptor read/64, error -110
Jun 28 13:42:28 kernel: usb 4-2: new full-speed USB device number 4 using ohci-platform
Jun 28 13:42:38 kernel: usb 4-2: device not accepting address 4, error -110
Jun 28 13:42:38 kernel: usb 4-2: new full-speed USB device number 5 using ohci-platform
Jun 28 13:42:49 kernel: usb 4-2: device not accepting address 5, error -110
Jun 28 13:42:49 kernel: usb usb4-port2: unable to enumerate USB device
So just to clarify: you're saying that this device works fine in USB3 mode if it is plugged into the router after it has booted up, but it doesn't if the device is already plugged in before the boot? And in USB2 mode it works either way.
