Barddzen
I purchased a house built ~5 years ago and the builder wired cat5e for land line phones and had RJ11 ports in 3 locations throughout the house. I replaced all of the RJ11 with RJ45 and re-crimped the media panel cables.
After labeling everything (locations) I tested each line in each room and my tester (Master CT468) lit up all 8 wires as properly receiving a signal.
However, only 1 of the 3 ethernet lines run from the builder work properly. The odd thing is with my signal tester I get all 8 wires reporting properly, but won’t connect and get an IP. The lights on the switch don’t even light up. I tried all the usual suspects: bad crimp on both ends, cable, switch port, etc. and nothing seemed to resolve the issue.
My gut is telling me there are stapled lines somewhere but I haven’t got up in the attic and traced things yet. Before I start crawling, is there anything else I can do to diagnose the other two lines?
